跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
i6s Plus polarizer issues- dark screen on landscape mode
I replaced a 6s plus screen and my customer has custom polarizer glasses of some kind and when you look at the display wearing the glasses in portrait mode you can see it, but when you turn the phone sideways the whole screen gets 90% dark rendering it unseeable. I tested this with two screens and both same result. Is this a screen defect in the polarizer? I tested it on my 8 with screen replaced and through the glasses you could see fine both directions. Please help. My screens aren’t aftermarket either, they are mid grade from a company in GA. I’ve done resets, soft reset, replaced battery and nothing. Without the glasses the phone is 100% perfect and you can see it perfectly. Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
the issue is with the polarizer. if they are oem lcds then whoever is refurbishing them is using low quality polarizers.
good quality polarizers use circular polarization, while the cheap ones use linear polarization.
这个答案有帮助吗?
得分 0
1条评论:
i refurbish screens myself and also ran into this issue awhile back.
完成的
添加一条评论
添加你的答案
baileytripp07 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 90
