跳转到主内容
修复你的物品
维修的权力
配件 & 工具
The Asus Transformer Book T100TA is a full Windows 8.1 hybrid tablet.
71 个问题 查看全部
My asus stuck on logo!
My asus 2-in-1 wont boot past the asus logo, and keeps restarting
I have tried to boot from usb (windows 10 media creation tool) from bios but it doesn’t work.
Please help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
2个回答
最有帮助的答案
Hi,
Insert USB recovery drive into laptop.
Start laptop and get into BIOS (press F2 after power on and before Windows "boots") and enable Legacy USB or CSM (not sure re your laptop).
Change boot order to USB 1st boot option, save changes, exit BIOS and restart the laptop.
When in Windows Recovery Environment, select Troubleshooting > Advanced > StartUp repair and follow the prompts.
Do not select Reset this PC as you can erase all your data and reinstall Windows if you are not careful.
这个答案有帮助吗?
得分 1
评论:
I have tried that, there’s no csm option in bios but i changed the boot order to usb and its still doing the same, it doesn’t seem to work
完成的
添加一条评论
[fixed]
The problem is fixed
I was trying to boot my 32 bit pc with 64 bit windows
Just made another bootable usb with 32 bit windows this time and its working fine.
Thank you for your consideration
这个答案有帮助吗?
得分 0
评论:
how did you get it to read the USB?
完成的
添加一条评论
添加你的答案
Omer Ahmed 将永远感激不已
浏览统计数据:
过去的24小时: 1
过去的7天: 9
过去的30天: 31
总计 1,528
