The motor cycle dies after about 30 seconds
i have a 95 sportster battery is showing 12.5v and a full tank of premium fuel , the bike starts and runs for about 30 sec and dies, i can see the gas spraying but the bike won`t stay running
This sounds like a gas issue , has it been sitting up ? I would check carb , It may be gunk up from sitting with gas in it , if this helps you great , if not reply
这个答案有帮助吗?
also check fuel flow , it can also be not flowing good , (check for TANK TRASH if flow is not good)
It sat over the winter on a battery tender and had it tuned up before winter, well I took the tank off to paint it which all I dissconnected was the crossover fuel hose that leads from obe side of the tank to the other and the 2 fuel hoses on the petcock I took the petcock off to paint, well when I put it back on the bike and start it, it only runs for about 15-30 seconds I see the fuel spraying in the carb
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 2,144
If it is a carburettor than most likely it is the idle circuit. Take a look at your filter, is the fuel running through that OK? You might need to pull your carb and give it a thorough clean.
由 sm_vulkus 完成的
