跳转到主内容
加入维修社区 - 创建账户
Third generation of the Integra, the last of which would be called "Integra" in North America.
DIODE blowing and don't know why
I have a 2000 Integra with b20 when I go to shift outta 1st gear into second, the car just dies, look under the hood and the EFI/EM 15 amp fuse keeps blowing, I would change it out and car will start right back up, but keeps blowing that same fuse, even tried going a lower amperage, checked ignition coil, spark plugs, don't know why
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
You dont want to try a lower amp , you would want to try a higher amp to be a little stronger , But dont do it , look around for a short , when your driving and changing gears you motor moves , it can be moving and touching a wire some where , you can reply if you dont see any wires , I will try to help you !
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Damien 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 22
总计 254
