Why is my battery heating up and loses power
One of the batteries of my club car, specifically the one that has connection to the regulator heats up when in use and during charging. And you the cart loses power after an hour of use
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 155
Does this Battery have any bulges in the side, or is it abnormal in shape? If so it is likely bad and needs replacing. Other than that, your regulator may be faulty, find its specifications and see if it checks out.
由 sm_vulkus 完成的
This is already the second battery. The first one had bulges and had low voltage. I replaced it with a new one and it seems it going that way too. Could it be the regulator?
Thanks sm_vulkus
由 Paul Gan 完成的
