跳转到主内容
修复你的物品
维修的权力
商店
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
1839 个问题 查看全部
Can Make Calls, But Cant Hear Them
Hello,
i have a iphone 7 where i can make calls but i cant hear them at all when either using the earpiece or when i plug in headphones. the speaker option is also greyed out.
i have gone in to DFU and restored/updated the phone but there has been no change.
any advice would be appreciated!
Thank you
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
已选择的解决方案
Hello the IC Audio have to be soldering again no matter how many times you restore or reset device it will stay in the same this is something that 7-7+ are having
这个答案有帮助吗?
得分 2
评论:
well that is not ideal, but it was the answer i was looking for. thanks for that!
完成的
It definitely sounds like a faulty soldering on the Audio IC chip and this can be fixed by the jumper wire - reball method.
A somewhat difficult task if you are not familiar with this type of repair level.
I have fixed 5 phones with this exact same issue, already fixed.
完成的
添加一条评论
添加你的答案
James 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 82
