跳转到主内容
修复你的物品
维修的权力
商店
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1188 个问题 查看全部
Ear Speaker and Front Camera working on and off
I have an iPhone 7 plus that I recently repaired that the ear speaker works randomly and the front camera is very slow at coming up and/or sometimes doesn't work in apps such as snapchat. This iPhone has been fixed previously and has been working fine.
Now I've replaced the front camera and speaker with a known working original with the same results. I also uncovered another issue. The phone will get stuck on the Apple logo after rebooting and will only boot normally after I do a hard reset. I tried different batteries and a different front camera flex with the same result. At this point Im scared to update to 11.3.1 or even restore it, because I'm afraid it wont boot properly and brick the phone
Any words of wisdom before the customer makes an insurance claim? Is this maybe a software issue and not a hardware issue?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
已选择的解决方案
The iPhone 7 series of devices suffers from issues with the Baseband IC, Audio IC and weak traces on the pcb which crack and break. It is a similar design flaw to the iPhone 6 Plus, known as Touch Disease. On the iPhone 7 series, the weak traces are underneath the Audio IC.
In many cases an internal short within the Baseband IC causes the boot looping, which unfortunately, is not repairable because the Baseband is code locked to the logic board. It can also be caused by a broken trace underneath the Audio IC. Replacing the Audio IC and strengthening the weak trace with a micro-jumper can repair this.
If you are curious about the technical nature of these failures, you can listen to this video from Jessa and this one from Jason at STS, they go into a lot of detail regarding this issue. It could be BB or Audio but the info in the video should help you figure out which one.
这个答案有帮助吗?
得分 3
评论:
Thanks for the info. I will definitely look into this further. Is this something that could have been caused by me? Im extremely careful with removing the flex. The customer did admit to getting some water in the area where the flex connects although there is no visible water damage.
完成的
I doubt you (an experienced tech) damaged multiple flexes...
完成的
Im going to close this and accept your answer. The videos you linked are the exact symptoms Im having. Thanks again.
完成的
Great! Good luck on the fix.
完成的
添加一条评论
添加你的答案
Brian Wood 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 12
总计 359
