跳转到主内容
A BTX computer introduced in 2006 using a Intel LGA775 socket processor. The 5150 is identical to the E510.
13 个问题 查看全部
I'm having start up issues on Dell Dimension 5100
When I press the power button only lights 3 and 4 are green on the front and the screen is saying "in power saving mode- move mouse or press any key on keyboard" still nothing happens.
PS this is the first time I've powered it up in about 3 years (trying to retrieve old files!)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
In my experience there are usually three things that can fix this issue.
1. Reseat the memory (Also it could be bad memory)
2. Replace the power supply.
3. It's an issue with the motherboard and it will be replaced.
Now, if you only need to get files off and you don't care to fix the computer, buy an external hard drive caddy. They can be had for $20 or so and connect via usb. You just take your hard drive out and sit it in the caddy. It basically functions like an external hard drive at that point.
这个答案有帮助吗?
得分 0
添加一条评论
Here’s some key things to review:
  • Has the memory been recently replaced(Memory only lasts 2-3 Years)
  • Has the CPU been recently replaced(CPU only lasts 3-4 Years)
  • Have you reset the CMOS
  • Have you tried replacing the CMOS Battery(Typically replaceable with a CR2032 Cell Batery)
  • Is your CPU compatible with your motherboard(Sometimes a new CPU will not play nicely with your motherboard)
  • Are you using DDR2-400(PC2-3200) or DDR2-667(PC2-5300)
Sometimes new components will not play nicely with older systems. Check the compatibility of all of your components.
Generously,
Richard Smith
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Andrew Clarke 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 184
