跳转到主内容
The 2004-2008 F-150 truck was introduced in January 2003 for the 2004 model year as the redesigned eleventh generation of the F-150 lineup.
56 个问题 查看全部
engine knocks when hot when going slowly
engine knocks bad when hot only when trying to go slow like a drive through. put in neutral and give a small rev and it stops.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
First things first, get it scanned and see what codes come up.
Knocking implies bearings, usually big ends and it doesn't usually go away with a rev.
But what you call knocking I may call pinging. So are you saying it sounds like an old diesel with that death rattle they have in the top end. Or are you saying it has a dull thudding noise coming from the bottom end?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Robert Carter-Wood 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 37
