跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
BSOD, no vibration, static from both speakers
Hi guys
I've recently stumbled upon bad suprise with my iP7. IT was barely dead but iTunes and drFone recognized my phone. One problem I solved by myself. IT was overheating and had those problems I mentioned im topic. After battery change overheating was gone but BSOD and no vibration stay. In addition, now a silent static noise from both speakers is present while IP is charged or charging. Do you have aby ideas what could cause a problems?
Update (04/29/2018)
That's it
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
This is a possible indicative of hardware failure. The speakers and graphics unit could be at fault. I’d say send it into Apple.
这个答案有帮助吗?
得分 1
7条评论:
You may have also gotten a bad battery on arrival.
完成的
I would like to add that iP drains baterry very quick. I can send you a photos do you can tell if battery is ok.
完成的
What do you mean by IP? Sorry, I’m not that great with IPhones. Also, what is the model of the IPhone 7? Anyway, I’ll need the photos to see if the battery is okay.
完成的
By saying IP I mean iPhone ;)
完成的
I've updated question with photo
完成的
显示更多的2条评论
添加一条评论
Dr done is a scam.
The issue is probably caused from the bad battery making software get corrupted on the phone.
You'll probably need to restore the phone using iTunes or 3Utools which all data will be lost, try update first just in case you want to keep data.
If you get iTunes restore error 4013 then it's definitely a hardware fault on the logic board.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Alan Zimny 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 66
