跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Will a iPhone 6s front camera work on a iPhone 6?
I just broke my front facing camera on my iphone 6. Will the 6s camera work on the 6? The 6s front cam is a few megapixels more than the 6 front cam and I'd like to try it. The connectors look in the same spot and same number of pins where where it plugs in, but the cable itself is a little differently shaped, but again, connectors are in the SAME SPOT.
See pic here:
https://i.ebayimg.com/images/g/cpkAAOSwF...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
9个答案
最有帮助的答案
yes it works, we use them sometimes when we runout of 6 front cams.
这个答案有帮助吗?
得分 3
5条评论:
Ok, so eventhough the cable itself is shaped a little different, it still fits? Good to know. And I think the 6s front cam is higher mexapixel right?
完成的
And, while I'm here asking, how about the rear camera>? WOuld a 6s rear camera work to replace an iphone 6 rear camera?
ALso, will the iphone 6 be able to use additional megapixels the 6s cams have??
完成的
I'll try for you next time I get chance but I don't think the rears are interchangeable.
完成的
Ever find out if the rears cams from 6s and 6 are compatible yet? Never found out.
(update: I still didn't get around to installing yet, but I will soon. The 6s front cam/proximity sensor cable into an iphone 6. As mentioned by Chris is works. My next question is, I'm assuming it will work better since the 6s front cam does have higher megapixel? Hope it's not scaled down due to hardware and it will perform better than the old cam?)
完成的
DO NOT TRY IT !!! i tried to see if i could put a better camera on my 6 but the processor just gets really hot and starts burning.
完成的
添加一条评论
此回答最初是针对另一个问题
Officially, these are not compatible; looking at the flexes, they are a little different. However I saw the other day an answer from a repair tech that indicated they were interchangeable (Can the iPhone 6 Plus camera fit in the iPhone 6?). I haven't tried myself but checking on a few vendor websites, none of them list them as compatible.
Hopefully someone will answer definitively otherwise, you will have to try it yourself and report back so we can all benefit.
这个答案有帮助吗?
得分 2
2条评论:
Very cool, yea, you mean the last post on your link? Interesting.. Hopefully he can chime in with more info.
完成的
It’s working
完成的
添加一条评论
此回答最初是针对另一个问题
Hi there, Gideon Here I am a Zambian and I am from swaping the iphone 6s 4.7” front facing camera with the cable to iphone 6 4.7” and it works and the camera has improved thank you for trusting me
这个答案有帮助吗?
得分 1
添加一条评论
I do not believe that these parts are compatible.
这个答案有帮助吗?
得分 0
添加一条评论
此回答最初是针对另一个问题
I have done exactly that and yes it works, really wasn't expecting it.
这个答案有帮助吗?
得分 0
添加一条评论
But do you get use of all megapixels on the 6S front camera, or will it only use the 1.2 mp which the iPhone 6 normally has?
I have also tried it and can confirm that it works with the 6S front camera on the iPhone 6, but don’t know if it works the other way around though (6 front camera on iPhone 6s), I guess it should?
这个答案有帮助吗?
得分 0
添加一条评论
此回答最初是针对另一个问题
Can 6 front cam work on 6s,this has not been answered yet,anyone?
这个答案有帮助吗?
得分 0
1条评论:
Can 6 front cam work on 6s?
This has not been answered yet,anyone?
完成的
添加一条评论
此回答最初是针对另一个问题
Can i use an iPhone 6s rear camera on iPhone 7?
这个答案有帮助吗?
得分 0
添加一条评论
此回答最初是针对另一个问题
Yes they are compatable.
这个答案有帮助吗?
得分 -1
3条评论:
Great to hear. I still didn't get around to installing yet, but I will soon. The 6s front cam/proximity sensor cable into an iphone 6. As mentioned by Chris is works. My next question is, I'm assuming it will work better since the 6s front cam does have higher megapixel? Hope it's not scaled down due to hardware and it will perform better than the old cam?
完成的
Does it cause any issues swapping a 6s front cam into the 6?
完成的
What about swapping 6s rear with 6
Does it work
完成的
添加一条评论
添加你的答案
Jason 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 472
