跳转到主内容
加入维修社区 - 创建账户
这是第三代 Apple iPad 4G 版本的维修指南、拆解和故障排除信息,有 16、32 或 64 GB 存储空间可选。于 2012 年 3 月发布。可通过型号 A1430 (GSM, AT&T) 或 A1403 (CDMA, Verizon) 进行识别。维修时需要使用热风并小心撬开。
Not powering after changing housing
So i bought the housing for my old ipad 3 3g and after i replaced it, it was working for a while and afterwards it dont wont start up.
1. Not sure if its the battery, but after i get it out from the old one there was smell of UHU glue. (did i puncture the battery ?)
2. Its still working until i stack books up the ipad as i dont have a heat gun to stick the screen back. After i removed the book, it wont start up. (did i broke the lcd ?)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The smell of solvent is not a good sign, as you say, you may have punctured the battery. As for stacking books, if they were larger than the ipad and resting on the outside edge of the housing, then it should be okay. The exception here is if you stacked too many books, caused a deflection in the digitizer which could have damaged the LCD.
这个答案有帮助吗?
得分 2
3条评论:
What are the other signs of punctured battery other than the smell ? As of the books they are about the same size as the ipad. Should be around 1-2 kg i believe
由完成的 分享
You'll have to visually inspect the battery.
由完成的 分享
ive sent it to a local repair shop and they said it was the motherboard that broke :V they said i when too hard when changing the housing. I was careful and didnt go hard though
由完成的 分享
添加一条评论
添加你的答案
Lee Jing Yong 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 353
