跳转到主内容
This affordable large-screen Android phone sports a 5.7-inch display and large 3,400 mAh battery.
218 个问题 查看全部
My Zte max blue shut off and won't turn on
My phone screen went black when I went to take a picture. No vibration no lights will not charge. It was at 82% when it shut off. I have tried charging from a computer tried holding both volume buttons for 30 seconds then the power button. Tried the down volume button and power button what should I do. Only had the phone a month. Was not dropped or did not get went.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Press and hold the up volume button and power button simultaneously for 10 seconds. That is proper way of performing a hard restart. If that doesn't work, then take it to your service provider. If the phone is only a month old the if should still be covered under manufacturer warranty.
这个答案有帮助吗?
得分 0
1条评论:
Thanks for the attempted assist but this information isn't particularly helpful and also happens to be quite redundant given how many times it has been repeated both on this site and elsewhere. I have two zte blue max phones and both have done this same thing. One of them did it about a month ago and the other did it today. When I began fiddling with my newly malfunctioning phone it reacted similarly to the last one in that no resets, attempts to boot, and similarly futile actions all failed to produce a reaction. Out of curiosity and frustration I attempted to boot the phone that had failed a month prior. Surprisingly it was sluggish but booted successfully after a month of sitting in a drawer. Battery life was still up to 80% and it seems to work fine. The questions are what caused this, how can it be prevented, how did time stagnating change things and is there a way to solve the problem without waiting for so long?
I apologize if I have violated the etiquette of this forum as this is my first time here.
完成的
添加一条评论
添加你的答案
Brittany Franzen 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 722
