upgrade RAM in both slots required?
Do I have to upgrade the RAM in both slots of my mid-2012 13" MacBook Pro to the same capacity, or can I have a lower capacity (original 2GB or 4GB) chip in slot 1 and a higher capacity (8GB) chip in slot 2?
You can have different amounts of RAM per slot. It is gernerally advised to keep the ram the same, but it is not a requirement.
Hope this helps.
这个答案有帮助吗?
You can mix then as long as they are the same speed. You loose interleaving but the RAM increase more than makes up for it.
RAM Type: PC3-12800 DDR3L Min. RAM Speed: 1600 MHz
Details: Supports 1600 MHz PC3-12800 DDR3L SDRAM SO-DIMMs (204-pin).
Standard RAM: 4 GB Maximum RAM: 16 GB*
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 88
