跳转到主内容
replacing shattered front glass
Hi, I am tasked with repairing a model with a totally shattered front glass. It was so bad that the suction cups would not work, I ended up having to chip it off one small piece at a time. Scraping/chipping the glass shards/glass dust from the edges was the worst. The good news is that it is done and the LCD looks good.
My question: As long as the edges are cleaned of excess adhesive and the LCD is ok, is the replacement glass offered from the iFixit store all that I need to complete the repair? I see that the adhesive is included, any trick to the application? Thanks in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
I would run through the guide at least three times before starting. Make sure the inside of the glass is clean and the camera is ready to attach. This is not an easy job and you will need uninterrupted time to do it. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement
这个答案有帮助吗?
得分 2
1条评论:
I agree, although most of the work is already done. All that I need to do at this point is put the new glass on. I rad the instructions, but didn't see much regarding actually putting the new glass in place.
完成的
添加一条评论
添加你的答案
support0 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,682
