跳转到主内容
The 2004-2008 F-150 truck was introduced in January 2003 for the 2004 model year as the redesigned eleventh generation of the F-150 lineup.
56 个问题 查看全部
2005 ford f-150 lariat power seat problem
Seats move backwards and forward for a second then stops. It makes a squeal noise before it stops.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
Anybody ever figure out how to fix this. I'm having same problem with binding track (not the motor) on 2004 F150 Lariat. Motor will move seat barely backward, not at all forward. Had same problem a couple of years ago too and bought a used track assembly. That worked till a week or so ago. In the past I tried to take the track assembly apart to try and fix it but could never figure out how to do that.
完成的
添加一条评论
1个答案
same problem and found the gears on each end of the front motor (worm gear or track box gear not sure what it is called but they are malfunctioning. Trying now to clean and grease them . no parts so far i can find available
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Arlin Merry 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 1,107
