The third generation of the Toyota Camry in all markets outside Japan. 1991-1996 was also called the XV10 series of Camry vehicles.
mike vernon @mikevernon
声誉积分: 1
发帖于: 2018年4月23日
My car has an oil leak. It also blows back oil through the dip stick
这是一个好问题吗?
tcagle53 @professorc
声誉积分: 8.2千
Professor C's E-repair and Upgrade Service
24
12
8
Sounds like your PCV valve needs replacing.
这个答案有帮助吗?
oldturkey03 @oldturkey03
声誉积分: 781.6千
1.1千
893
2.3千
mike vernon possibly blown piston rings. Check or replace your PCV valve as suggested and then do a leak down test. It will tell you a bit more about what is going on with your Camry
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 53
