跳转到主内容
A home audio speaker for iPod by Bowers and Wilkins introduced in 2007.
26 个问题 查看全部
mini toslink (3.5mm) audio input doesn't work
The toslink jack connection to the zeppelin air will work only if I'm doing a small pressure with my fingers to the right side (with reference to the back of the zeppelin air)
I could use every help :)
Thanks
Update (04/28/2018)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
Seems as though the socket may be faulty, loose or have a bad connection to the motherboard.
What type of connection are you using?
If you are using a mini Toslink cord then try using a mini jack stereo audio plug and check if that works normally (or vise versa).
If it is the mini Toslink that you're having the problem with then it may be a socket connection problem with the motheboard.
If it is the mini audio jack that you're having the problem with then it may be the socket itself or a socket connection problem with the motheboard.
Here is a link to an ifixit How to disassemble a Bowers & Wilkins Zeppelin repair guide.
It is in German and essentially it describes how to open the device to repair a fuse so hopefully it may be of some help. (I couldn't locate any other teardown info or service manual for the device, you may have more luck)
Update (04/28/2018)
Hi,
Does the socket seem "loose" when you try to gently move it from side to side?
If it is soldered correctly there should be no movement.
Looking at the pictures you posted I'm wondering if there is a dry solder joint on one of the connections of the socket.
I can't magnify it enough to see if it is just a spare terminal or whether it should be soldered to a track on the systemboard. It would explain the fact that applying pressure to the right side of the socket would make it work. There may be just enough movement for the connection to be made.
I've highlighted the suspect connection in the image below.
(click on image to enlarge for better viewing)
I may be totally wrong about this of course.
这个答案有帮助吗?
得分 3
1条评论:
It seems that the socket is loose, so the solution would be to replace this item, but it seems impossible to find it on eBay. I don't even know the part number.
完成的
添加一条评论
添加你的答案
Nunes 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 1,638
