跳转到主内容
Standard and high definition handheld video cameras by Sony.
116 个问题 查看全部
DCR-HC21 Flip screen all black
The flip screen on my DCR-HC21 is responding to my touches but isn't displaying anything other than an all black screen. Fixable? Worth repairing?
Also I inadvertently shut off the viewfinder and, obviously, can't locate the command on the touch screen to switch to it to even view a tape that's running or what I'm recording.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@steveyv shine a light at an angle across the LCD. See if you can make out silhouettes. This will verify if it is your backlight., Most likely so you need a new LCD but if you see silhouettes etc. it is possible that you have a board error on PD-237 which is the LCD/backlight driver board. Here is how you get to the LCD
If you find that it is your backlight that is not working check CN608 on the PCD PD-237. Pin 6 should have 2.6V and pin 3 -15.5 Let us know what you find and post some good pictures of your camera if you need assistance with identification etc. Use this guide 在已经存在的问题里加入图片 for that
replacement LCD's are available at ebay etc.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Steve Vale 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 18
总计 827
