跳转到主内容
华为首款配置了麒麟970芯片的智能手机。 发布于2017年 11月。
20 个问题 查看全部
Water damage, black screen, phone still on! Won't turn off!
I used my apparent water resistant phone in the pool and now the screen of my phone is black, my phone is on, and unable to be turned off, the screen is black and every so often the phone vibrates as if a notification has come through or as if the phone is being used.
Please help!!! I'm furious this has happened as I did all the research about the water resistance of this phone and only used it to its abilities.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
2个答案
最有帮助的答案
Which phone is it? The only thing you can do with a blank screen is try a hard reset (search for how to do that on your phone). Check your warranty for what the conditions are for you to have it repaired or replaced and also for what level of water resistance it actually offers. If you were within the limits it should be no problem. Basically whatever happens it will need to be examined for water damage by a repair technician to find out what parts have been affected. To be quite honest I'd never trust phones + water no matter what the advertising says!
这个答案有帮助吗?
得分 1
添加一条评论
You are not supposed to use "water resistant" phones in the pool. Or the shower. Or the beach. They are just rated to be safe in case you drop them in the water by accident, not on purpose. So if you spill a drink on it, it'll be fine. If you're taking a bath with it or literally using it in the pool, it won't be fine.
Your own fault. The manufacturer will not take in charge the device. And don't worry, other manufacturers won't fix their own "water resistant" devices if there's water damage, warranty or not.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Meaghan Medcraft 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 22
总计 2,564
