跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
Error 4014 What should I look for?
So I understand this could be a NAND problem, but I highly doubt that is it, as the user of the phone said he was using it and the phone just stopped working completely. The phone is stuck in DFU mode and restoring with iTunes will work further than an actual phone with a faulty NAND will. But I still recieve 4014. Before I go to great lengths to remove the NAND chip and reprogram it, I want to know what things I maybe need to look for?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
have you checked pp3v0_nand for shorts
这个答案有帮助吗?
得分 3
3条评论:
On the iPhone 7, which capacitors relative to the NAND should I check?
完成的
try c1719 and c1727
完成的
@tech_ni Checked C1719 and C1727, Both are fine and only one side is grounded. Though just to make sure I removed both and attempted startup and it still had error 4014. (I put them back on BTW)
完成的
添加一条评论
Here is what Apple says about it.
https://support.apple.com/en-us/HT201444
I think iPhone 7 is new enough that apple may repair or replace it for free.
这个答案有帮助吗?
得分 2
3条评论:
@avanteguarde Apple was a jerk, right when I told them what error it was after their LOOOONG Troubleshooting, they said it would need to be replaced. And would cost me.. -_-
完成的
@noah_smith that's disappointing. In that case, find out what credit card you used to purchase the phone with. Many times the credit card company has its own "insurance" and will cover an extra year on your warranty. If it does, follow your credit cards guidelines on how to get comp'ed on the repair.
完成的
Ok, thanks for your help! I'll give my CC Issuer a try, usually CC companies are nice and will help like you said.
完成的
添加一条评论
添加你的答案
Noah Smith 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 2,483
