跳转到主内容
The Bose Wave Radio AWR1-1W, also known as the Bose Wave Radio I, was released in 1993. A countertop AM/FM radio system with a high performance stereo tuner and two independent alarms.
39 个问题 查看全部
loud buzz when you turn it on
awr1-1w. When I turn it on there is a very short, loud buzz from speakers. Then no audio output. display works fine and shows choice of station and time when turned off. keypad on top functions perfectly just no audio after initial loud buzz.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Hi @sierra26 ,
Try connecting an external audio source via the aux input to check if the output audio is OK or not. Press the Aux key to select input.
if it is OK then at least the amp section of the radio is OK.
Have you checked the antenna connections?
完成的
添加一条评论
2个答案
最有帮助的答案
Hi Mate, not sure if you’ve managed to fix this thing yet as it’s been a few years, but I fixed mine (which had the same fault) today by replacing the two small 0.47uF 50v electrolytic capacitors in front of the amplifier chip, hope this helps!
这个答案有帮助吗?
得分 2
1条评论:
This absolutely worked on my radio. Capacitors cost 54 cents each. Shipping was $5. Still worth the price of admission
完成的
添加一条评论
@sierra26 noise like that is usually related to bad capacitors etc. You will have to disassembly your Bose and take a look at the components. Check for obvious damage like leaking or bulging capacitors. etc. Post some good images of your boards so we can see what you see. Use this guide 在已经存在的问题里加入图片 for that. Of course you also want to make sure you check the speaker. Consider connecting a different speaker for testing purposes only. Use these guides Bose Wave Radio AWR1-1W to wrok on your Bose.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jim 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 65
总计 5,487
