跳转到主内容
型号 A1213或A1218,闪存容量:8、16及32GB
216 个问题 查看全部
Can't Adjust Screen Brightness!
My iPod Touch 1st. generation won't allow me to adjust the screen brightness, even though the brightness slider moves. I've recently taken it apart. If anyone knows how to fix this issue, help would be greatly appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
Did it just happen when you took it apart? If you haven't yet, try a restore. Sometimes the silliest of issues are hardware related. It could be that the backlight on your particular screen has died, which would be unfortunate. If the restore fails, I'd suggest (since you've already taken it apart) looking closely over the display cable for any corrosion. You could then use some >70% (90 if available) isopropyl alcohol to swab it.
CAREFULLY.
That being said, best of luck.
-tabormeister
这个答案有帮助吗?
得分 1
4条评论:
the brightness is stuck on the highest setting.
完成的
oh gosh, well that's totally different. Was it like that before you took that apart?
完成的
no. i was curious which part inside controlled the brightness.
完成的
There isn't any hardware part that specifically controls brightness that you could replace, it's either the screen, the software, or the entire mainboard, because it's a touch. Seeing as how all of those except for software is expensive, my answer was to try the easiest thing first, then the next most complicated. It's very possible that the cable didn't reseat properly, or that the software decided it didn't like being taken apart. (that happens with a lot of iPods.) If restoring it and reseating the cable/swabbing it with isopropyl alcohol don't help, then I'm afraid without looking at it I can't help.
完成的
添加一条评论
添加你的答案
Patrick 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 4,074
