跳转到主内容
The smaller version of Google Home voice-activated speaker, equipped with Google Assistant. It was announced on October 4, 2017 and released globally on October 19, 2017.
Why it's not wireless anymore?
It only powers on if it's plugged in to the charger. It use be a rechargeable device.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
After doing some research I can conclude the following,
According to few forums and google support, the Home Mini does not have a integrated battery and only works using the 5V 1.8A adapter.
None of the Google Home products feature this anyway (Which does make me wonder why you'd think it was rechargeable before)
So basically, sorry but no it does not have a rechargeable battery.
HOWEVER, the Google Home (standart, not mini) has an option to get a "portable battery base", which gives 8 hours of use (Info found here: https://www.cnet.com/news/add-a-portable... )
这个答案有帮助吗?
得分 3
1条评论:
The power consumption of the Home Mini (= GHM) is averaging 0.25A at moderate volume (50%).
On a power bank with a sufficiently large housing like Tomo V4 (bought at banggood.com), the GHM can be carried well through the house. The micro USB connector shell must be small enough to fit into the recess on the housing of the GHM. (!)
I have equippet the Tomo V4 with 4 lithium-ion batteries (NCR18650B, 3400mAh). It has powered the GHM at its 2 amp output almost daily for over 4 months. I am using a magnetic charging cable, which can be easily connected during operation of the GHM without mechanically stressing the micro USB socket of the power bank's charging input. The Tomo V4 can't bei charged in parallel, but further unloading is prevented.
Are about 24 hours of "wireless" operation on a power bank with "24 Ah capacity" sufficient?
完成的
添加一条评论
添加你的答案
Emiliano 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 452
