跳转到主内容
加入维修社区 - 创建账户
三星新旗舰的大号版本,盖乐世S8+。发布于2017年4月。
Cracked screen half screen is white
I dropped my phone and in the middle of the screen all the way to the right edge there is a crack and now a horizontal line and from there down the screen is white static and I can't see anything but I can still click on apps. What is broken or need to be replaced?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
4个答案
my guess is the entire display. Unless you have like 5 specific machines that will put all your cheap separate display parts together properly, I'd just look into the easiest display replacement method possible, usually a $40-60 part, a whole display, lcd+digitizer/glass, sometimes they'll come with a mid-frame or whatever it directly connects to. Find videos on the DIY job, at least three to get familiar with every little step, trust me, I've wasted a lot of money on breaking new displays/glass trying to rush this stuff, make sure you know how to adhere the display to whatever it connects to like a mid-frame and/or bezel, what adhesive, glue and/or double sided tape, AGAIN know the steps to the very end before you attempt. Don't work on carpet. Maybe get one of those anti-static wrist bands.
I broke my last display screwing up the last step, stuck it down a hair off screwing it up then had to take it back off and broke it. Go slow. Good luck
这个答案有帮助吗?
得分 0
1条评论:
How much would that cost if I took it to a professional repair?
完成的
添加一条评论
This is the same problem with me. My 10 Viking pro is broken so I used my Samsung Galaxy S8+. Soon I made a HUGE mistake. I took it to the store with me and my mom. We had no car so we had to walk. Soon when we were done getting groceries, I accidentally dropped it. I was embarrassed. It was already cracked, but it didn't have bad landing. Two days later I turned it off to get my little sister at are friends house. Soon I found her already on the porch. “Get in here!” I said. Soon I went back on the phone till it showed white on the bottom half while the top has solid black like my soul was. “I have no electronic now…” I said in my head. My mom won't let me play on her PS4 or her phone. My sister won't let me play on her tablet, so I take it in the mornings. I'm sorry this is not an answer. When I find an answer, I'll send it to
这个答案有帮助吗?
得分 0
添加一条评论
Mine it's not cracked but it's displaying half screen
这个答案有帮助吗?
得分 0
添加一条评论
I have a white screen how to fix it
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jene Bigness 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 23
总计 14,736
