The Motorola Moto Z Play (model number XT1635) is a droid smartphone that was released in September 2016. The Moto Z Play can be easily distinguished by the word “moto” placed at the top and the square home button placed at the bottom of the front of the phone.
39 个问题 查看全部
I dropped my phone in pool for 3 seconds!
HELP! I dropped my Moto Z2 play phone in a pool 8 inches deep. I picked it up immediately and shook it out but then the screen went wonky. I put it in a bag of rice for 3 days....there is a white light that blinks when I plug it in but then disappears and won't turn on. is there a reset buttton or what can I do to make it work again. I thought these phones were water resistant? So disappointed and I really can't afford to purchase another one.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
3个回答
已选择的解决方案
Hi @irenef ,
Motorola doesn't claim that the phone is water resistant, simply that it is water repellent. Subtle difference but enough to get them out of trouble if it is immersed in water.
This is what they say on the product specifications:
"Advanced nano-coating technology creates a water-repellent barrier to help protect against moderate exposure to water such as accidental spills, splashes or light rain. Not designed to be submersed in water, or exposed to pressurized water, or other liquids; Not waterproof". (the highlighting in the text is my addition to the quote).
As to repairing the phone, as you know liquids and electronics and electricity are not a good mix.
The liquid causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion process starts immediately and continues until it has been cleaned properly
Rice is good to eat but does nothing to fix the problems caused by corrosion.
Don't Put Your Device in Rice. Here's Why
First do not turn on your phone and then you need to remove the battery as soon as possible from the phone to minimize further damage.''
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 90%+ (available at most pharmacies) to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% or less, can contain scents and is not as effective. If you do check the label to verify the amount of IPA.
Here is a link that in general, describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work correctly again.
Here's a link to a video which shows how to dis-assemble your phone, which may be of some help
If this process seems too daunting, take your phone to a reputable, professional mobile phone repair service experienced in liquid damage repair and ask for a quote for a repair.
If you decide to do this, do it sooner than later.
这个答案有帮助吗?
按维修分数 2
评论:
Does the motherboard need to be changed if the phone fell into water? My battery has a question mark in it, wheat does that mean?
Hi @ogechiike ,
It depends on the amount of water damage that has occurred.
The battery may have to be replaced however.
The extent of the damage can only be ascertained once the phone has been opened and inspected.
To try to contain the amount of damage and to minimize any further damage DO NOT turn on the phone before either removing the battery or seeking professional help.
添加一条评论
@irenef it really does not matter how long it was in the water. What does matter is which part got immersed. First thing is to skip the rice. It does not work. Rice is a great food but a lousy tool. It will not clean your phone nor will it prevent corrosion. As with any immersion, the importance is to not turn it on, or trying to sync/charge it, as this may increase the likelihood of shortcircuiting any components. Remove the battery, and disassemble it right down to the logic board. Use this guide or something like this to at least get you into the phone. You must remove all EMI shields that are on your logic board. Clean everything with isopropyl alcohol (90%+) and a soft brush, including all connectors and cable ends. Use this guide 修复iPhone 的进水故障 to see how it gets done. Even so it was written for an iPhone 3G all the points about the cleaning still apply to your phone as well. Check for any burned or missing components. You may have to repeat this step a couple of times. the best way to clean it would be by using an ultrasonic cleaner. Once it is cleaned, reassemble it and replace the battery, then reevaluate for any real damage. So, definitely clean it very well. Hope this helps, good luck.
iPhone张图片
指南
修复iPhone 的进水故障
难度:
困难
1 - 2 hours
Motorola Moto Z Play Screen张图片
指南
Moto Z Play Screen Replacement
难度:
中等
这个答案有帮助吗?
按维修分数 2
添加一条评论
There is no water resistant phone, one brand try that, those phone resisted normal water, but not salt water, so they paid a lot in waranty, you just had bad luck, but maybe is only the screen that is bad, by the way, is better to put the phone in isopropil alcohol for a day and then let it dry for another day or two.(i did that with my sister phone, after that i took the motherboard and scrub the parts where i found corrosion)
In any case, you can know if the phone turn on by conecting it to a pc, if it conects after you try to turn it on then you have to replace the screen.
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
Irene Filipponi 将永远感激不已
浏览统计数据:
过去的24小时: 22
过去的7天: 137
过去的30天: 506
总计 2,772
