跳转到主内容
Repair guides and support for the first generation Town Car, a full-size luxury sedan manufactured by Lincoln.
My Brakes Don't Give Resistance
My brakes are fine and I just replaced the lines, but the pedal itself doesn't give any resistance. I get it down to the floor before I actually stop. How do I correct this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Were the brake lines bled properly after installation? Even a small air bubble in one line will make brake pedal feel spongy.
https://lincolnforums.com/forums/#
The above forum may help too.
Best o' luck.
这个答案有帮助吗?
得分 1
6条评论:
Yes, the mechanic who sold it did the bleeding
完成的
I'm not sure why, but that reads funny.
完成的
Yea, it kinda does. I'm gonna try bleeding them again and see if that helps
完成的
Well, it's been a while...did you ever get the brakes working proper? Just curious.
完成的
When you say lines, what do you mean?
brake hoses?
if so why did you replace them?
完成的
显示更多的1条评论
添加一条评论
Sounds like your issue is the portioning valve. This valve pushes the correct amount of brake fluid to the brakes, and is what gives your pedal pressure. Had this same issue with my 1999 Ford Taurus, would push the pedal to the floor before any minimal response. I hope this gives some insight to your issue, as I'm no car genius. Good Luck.
这个答案有帮助吗?
得分 0
2条评论:
Do you know any way to correct it?
完成的
If the valve is bad, it can be a very expensive replacement
完成的
添加一条评论
添加你的答案
Bradley Edwards 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 14
总计 311
