这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4559 个问题 查看全部
Unable to activate Touch ID on this iPhone
Hello. I recently replaced a screen assembly on IPhone 6 and now the Touch ID doesn't work.
I moved the original home button onto the new screen and even bought a new flex cable . The home button is working fine but there's a message which says that the iphone is unable to active touch ID?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 1
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
4个回答
已选择的解决方案
Take a close look at the Home Button flex (the short one from the button to the connector) as well as the Link flex that goes beneath the LCD shield. It is possible that either the flex or one of the connectors was damaged or torn during the repair. If the link flex is torn or its connectors damaged, you can replace it again. If the Home Button flex or connector is damaged, it may be repairable but if the damage is too severe, you will have lost TouchID forever...or until you have Apple replace the screen and HB :>).
这个答案有帮助吗?
按维修分数 3
评论:
Highly unlikely that it is the link flex.
@rocky85
We can only offer ideas and suggestions seeing as how we don't have access to the device itself to properly diagnose the issue. I have seen lot's of damaged link flexes following failed DIY repairs. It could be the connector or the link flex itself that gets torn. Either way, it doesn't hurt to look. Don't forget that the mission on this forum is to help fixers. Even if this doesn't perfectly answer the OP's question (and we rarely know because few people ever come back to say what helped or solved their problem), others will search for and find this answer and it may give them a good lead towards finding a solution.
As for your own answer, don't forget that the vast majority of replacement screens do not come with the link flex installed, it has to be transferred from the original screen to the replacement, hence why they tend to get damaged by fixers. On the iPhone 6S series, the link flex is embedded in the screen assembly.
@refectio Hello. Thanks always for the honest and in-depth answers :) I am currently working at a mobile phone repair shop and your replies are helping me hips with giving advice to my customers. I admire you so much. Thanks !
Thank you for the kind words @chrisp1989! Hopefully you will feel comfortable enough to start answering your own questions too.
添加一条评论
uh oh! problem is, that apple has the touchid paired to the logic board, so unless you use the original touch id, its dead.
这个答案有帮助吗?
按维修分数 1
评论:
Did not read question. Pointless answer.
添加一条评论
Try on the old screen, see if it works, before buying a link flex cable.
这个答案有帮助吗?
按维修分数 0
评论:
Didn’t think about that. I’ll check that out. Thanks
添加一条评论
Try cleaning all associated connectors and the home button with isopropyl.
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
Arturs Ozolins 将永远感激不已
浏览统计数据:
过去的24小时: 12
过去的7天: 75
过去的30天: 396
总计 11,748
