跳转到主内容
Fourth generation of iPad, released November 2, 2012, available in 16, 32, or 64 GB models. Model Number A1458
218 个问题 查看全部
Ipad 4 stuck in DFU Mode not restoring
Hello there,
I ve got an ipad 4 WIFI stuck in DFU Mode und i cant restore it.
The computer still recognizing the ipad but just in DFU mode. The screen is staying black.
It shows the error 4014 on itunes.
On 3UTools it says "no valid Serialnumber". And sometime it says "anable to switch from DFU mode to recovery mode".
Sometimes the ipads is trying to restart while restoring and the apple apears for a second but than disapears again.
Do you guys think its a software problem or a hardware problem.
Tryed running it barebone just the pcb but also not able to restore.
thanks peace üt
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Error 4014 could be caused by a worn cable, charge port or bad wifi. For your iPad, I would try switching cables, trying a different PC port, or replacing your charging port. I have replaced a few ports that have had the same issue and they've worked, but they have all been on iPhones and different iPads.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Niklas Jakob 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 474
