跳转到主内容
Released Quarter 2, 2014. Identifiable by Model Number: HBS-750.
11 个问题 查看全部
Why can't I hear the music on both side of my earphones?
I had this pair of earphone since Christmas and has been working fine, but all of a sudden I cant hear the music, I checked everything on the device the Bluetooth still connects to my phone and charges well, but I have to move the wires around and you can hear a faint sound but has to be in a certain position, I was told to open up the earpiece but I have no way too open, need help!!!!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Please how I fix the problem of not hearing my callers but they hear me? Please i need urgent answers. Thanks
完成的
添加一条评论
1个答案
已选择的解决方案
Typically, when you have to move the wires around to hear the sound. It means there is a bad wire connection between the speaker and the amplifier in the earphones. There is pretty much only two ways to fix this problem. The first is to tear down the earphones and try to manually reconnect or adjust the connection. The second is to just end up buying another pair.
Best Regards,
Drew
这个答案有帮助吗?
得分 1
2条评论:
I see, but the problem is there is no way to opening the earpiece and even tried using a razor to cut my own way in. but yet no luck, any recommendation??
完成的
This guide I attached below may be of help to open the earpiece. It is not my guide and I have not ever used these earphones, but I am trying to help based off previous knowledge and experience.
Best of Luck,
Drew
LG Tone Pro HBS750 Magnet Replacement
完成的
添加一条评论
添加你的答案
LelandAnagal 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 26
总计 1,336
