跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
iPhone turns on right after turning off
So I recently fixed a water damaged iPhone, fairly simple repair, just needed a new battery, screen and to reflow one of the touch ic chips (I know it is a bad practise, but I got this cheap damaged iphone just to get some experience on microsoldering and repairs in general).
The thing is, I have a quite wierd problem. Whenever I power off the iPhone, it turns off and right awat i turns back on again. It happens aswell when the battery is discharged, it keeps showing me the logo with the battery and the lightning cable.
The power butron is not faulty since the phone doesn’t lock or turns off by itself.
Can anyone give me a clue to why this is happening?
Thank you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
did you ultrasonic clean the board and do a full inspection for corrosion. Your repair sounds like there is a battery /power problem that needs troubleshooting to start. Water damaged phones are finicky-
这个答案有帮助吗?
得分 0
添加一条评论
id be checking under a microscope around the top front section of the board or near the lock flex fpc . You'll likely find corrosion shorting the power flex or something on its circuit causing the phone to think your powering it on.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
rapiteu 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 533
