跳转到主内容
A collection of guides and support to help with washer repair.
3474 个问题 查看全部
Lg wd80130f doesn't spin fast
Hi, my lg wd80130f does not spin fast after completing its wash cycle hence leaving clothes wet, sometimes it works if i unplug amd start the whole washing cycle again. When it doesn't spin after cycle, i can hear noise like relay is switching and light sound of motor who is trying to spin, but it can't.
From few days i let it complete its cycle and then i will go into its QC test mode and spin it from there. It works everytime but i want to fix it because if it fails to spin then it won't turn off and on few occasions (if i leave it anattended) it will keep running for overnight.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
REF: http://diagramas.diagramasde.com/otros/L...
The link above is the service manual for you washer. Start on Page 25 for troubleshooting the spin cycle.
Other thoughts: When you do the QC test, I'm assuming this is done with the basket empty. Is the water draining after the wash cycle? If not, look at Page 18 "Drain Trouble" and Page 23 for drain malfunction. Excess weight caused by water drainage issue would affect spin speed.
这个答案有帮助吗?
得分 0
添加一条评论
Did you find out what the fix was? I am having the same
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
manubali811 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 7,130
