跳转到主内容
加入维修社区 - 创建账户
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
iPhone 6+ won't turn on
I have an iPhone 6 plus that was working fine. I gave it to my cousin after I replace the screen and days later the new screen stopped responding. The only way it would respond to touch is if she would press on the screen very hard. Her friend ended up pressing on the screen very hard to the point it cracked. Then phone would turn on again after that but the touch was unresponsive. Later on, she slammed it on her bed and it turned off completely. It hasn't turned on since.
iTunes does not recognize it at all. I've replace the battery, the charging port and the screen and still no response. The motherboard however does get warm when plugged into the computer. What can be done? Any suggestions? Please and thank you!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
If you've tried a new screen, battery and charge port, pretty much the only thing left is the logic board. It could be a damaged connector or there could be a dislodged component in the connector area. If you want to, you should take a close look at the logic board, preferably with magnification to see if there is anything obvious.
Otherwise, you should have this looked at by a micro-solderer.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Nilsa Rodriguez 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 17
总计 646
