跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
1049 个问题 查看全部
Searching for service and no wifi
I just recieved this iphone SE, the phone was only searching and does not connect to wifi. i’m almost certain its this part(photo)
May anyone tell me if this ripped part is the one to blame and what part it is, honestly never noticed it before.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
that is absolutely ONE of the issues for sure. there is no guarentee that that is the only damage to the device, but the component is a WiFi network antenna pickup, and will improve your wifi and BT signal for sure
这个答案有帮助吗?
得分 2
5条评论:
From what I can gather of information its the WIFI antenna, but that wil only fix wifi if I’m correct?
完成的
this is highly likely. thats why you would need to run a diagnosis on the rest of it. however, it is still a manditory repair to get the device functional.
[关联产品丢失或禁用: IF124-043]
this is the primary cellular antenna, however, the screws being fastened to the housing, the mainboard coaxial cable, as well as the metal pannels all register cellular activity. replacing these one at a time until your issue is fixed is what needs to be done.
ALSO! be sure to check the device against your national blacklist.
完成的
What do you mean about blacklist?
完成的
if a phone is reported stolen, it is put on the blacklist. where it will not be able to be used on any carrier network. here in canada, we have access to check devices against this list, to verify if it is, but im not aware if it available in other countries. you may have to check with the carrier it is originally purchased from.
完成的
添加一条评论
添加你的答案
nicolay.94 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 73
