跳转到主内容
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
596 个问题 查看全部
Seeing an X over the battery icon in the menu after new battery
I reset the SMC and swapped out a new battery and I still see the X. Additionally, when I opened the case, this fastener was rattling around,
https://imgur.com/sRsuKyn does anyone have any idea what this is for?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
The loose part is a press fit stand off used on the logic board to mount the fan to or the heatsink.
From the looks of it I suspect someone put in the wrong screw as the bottom is pushed through.
As to why your battery is having troubles I suspect the loose mount shorted something and you still might have a piece floating around inside (pushed through plug).
这个答案有帮助吗?
得分 1
添加一条评论
So I'm assuming the mac is not recognizing the battery, there could be alot of things wrong, lets try basic troubleshooting first, does the mag safe charger indicate the battery is there? It would be an amber light on the charger if so, but a green if not. Also, can you use the mac without the charger even though there is no battery recognized? If you can, it is probably a software issue, if not, maybe a hardware issue. If I can get these answers, I can probably find a solution.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Afisherman24 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 44
