[iOS 11.3] Battery Health Beta - No Change after Replacing Battery
hello,
I have replaced battery on iPhone 6PLUS with a new one, most probably genuine OEM one (looks very good and original).
Unfortunately battery status stayed the same - SERVICE :(
Maximum Capacity also stayed the same which is poor 65% :(
I have double checked the battery with coconut and iBackupBoot and its 100% capacity and 0 cycles.
I have tried ERASE ALL CONTENT AND SETTINGS - no change
I have tried Restoring 11.3 from scratch in iTunes - no change
I have checked battery in iBackupboot again and still 100% capacity.
1. Is there a way to reset battery info capacity and service status?
2. How to do it?
3. Has anyone tried replacing battery and what happened with previous status and capacity number?
I have tried DFU restore but no change. Still "SERVICE" status and only 65% capacity :(
Will try to drain the battery to 0% and then charge to 100% again but I feel that has nothing to do with capacity number which may need some Apple Authorised Service Provider reset procedure :(
由 Windcatcher 完成的
I have tried downgrade to previous 11.2.6 without Battery Health and then upgrade to 11.3 but no change. Service status stays and 65% capacity is still there :(
由 Windcatcher 完成的
I am having the same issue on two devices, a 6 and a 6 Plus, I had the batteries replaced by Apple at one of their retail stores in South Fl, I contacted Apple Support, they had made an appointment for me to take the phones back to the store, the Sr. Advisor I spoke with did not know why the issue was happening.
由 Jose Figueredo 完成的
Hi Jose, did they correct the issue? I have the same problem. Thx Jiri
由 Jiri Prazak 完成的
Just left the apple store with the same exact situation. There was an initial half ass spiel about waiting 24 hours for the system to reboot when in fact they screwed up and admitted to it. The tech was simply not paying attention and put the same battery back in the phone, confirmed via 2nd diagnostic check. New battery says 100% with no prior data but I’ve lost 3 hours of my time.. smh
由 jonwheldon 完成的
显示更多的3条评论
