跳转到主内容
The Olympus Stylus 1010 is a 10.1 MP digital camera with 7x optical dual image stabilized zoom. It has a 14.7 MB XD-Picture Card. The camera is 99 x 56 x 25 mm and weighs 136 grams.
7 个问题 查看全部
usual SD card will not go in slot.Could something be blocking?
I have successfully used the card before now it only goes into the slot halfway. I do not see anything in the slot
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Try rotating the card 180 degrees and inserting it. It will only go in one way.
这个答案有帮助吗?
得分 5
添加一条评论
I have the same issue, it's not the way the card goes in.
I got it from a pawn shop. Can't tell if there is an old card broken inside, or if the popup housing might be broken.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ellie Ramirez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 416
