跳转到主内容
加入维修社区 - 创建账户
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
Mac didn't start. I...fixed...it? still won't start.
Long story.
My Mac crashed and wouldn't turn on. I've had this issue before, so I tried to go through the whole force start thing, but it still didn't work. I did a bit of research and ended up running an fsck repair. the issue was the volume which after a few attempts, repaired itself along with another thing which I can't remember. but it repaired itself.
It still didn't go to the user login page, so I kept restarting it until I finally got into the Disk Utility. NOTHING there worked except running first aid.
now everything is fine. volume is okay. internal physical disk is okay. External disk is okay.
but it still won't take me to the user login!
I had the opportunity to erase the disk completely, but that operation failed and now I can't find the disk and the recovery disk along with an external drive I had are completely locked.
help help help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Your system didn't come with any disks. I do recommend once you get things going to create an install thumb drive so you have what you need in case the problem happens again.
OK we're still stuck on a boat without a paddle! Now what??
Not to fear Apple give us a second option here. First you'll need to have access to the internet either via Ethernet or WiFi. What you'll do here is connect to Apples internet recovery server to install the OS.
When you restart your system press: Command (⌘)-R then arrow down to 'Reinstall macOS'
Reference: How to reinstall macOS See if that works!
这个答案有帮助吗?
得分 1
5条评论:
done that already. i guess it's the recovery HD that's locked, not a disk. it connects to the internet and prompts me to install but the HD is locked. and my external drive should've had time machine backups on it but they aren't showing up.
完成的
Is this a used system?
完成的
yes it's used
完成的
Why I ask is I'm wondering if the pervious owner iCloud locked your system on you remotely. This could explain why you're having problems here.
I think you'll need to visit an Apple Store to see if they can help you.
完成的
alright thanks. that was my conclusion as well
完成的
添加一条评论
添加你的答案
Caroline 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 179
