跳转到主内容
Comprehensive set of repair guides for playthings for children of all ages.
942 个问题 查看全部
Paw patrol life size look out- how to dismantle
My child has clicked the plastic periscope in place before the roof was put in and it is now stuck- how do I remove the plastic without breaking the toy so I can assemble it properly?!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
Morning. My little one has just done the same
完成的
How did you get it off please
完成的
Did anyone manage to fix this problem?
完成的
Yeah had same issue, its connected at the very bottom, couldn't get it out. Tried with butter knife, with butter on it to maybe get it greased.. no luck.. as it's connected at the very bottom tip - need to take that house apart, but ours was already on it. Ended breaking that tip clip off.. put red roof on and superglued periscope at the bottom and sticked it in haha
完成的
添加一条评论
3个答案
最有帮助的答案
It doesn’t look like it should really be a problem... I would try to fit the roof to the building as is with the periscope in place. There are usually tabs holding the pieces in place, I have had success sliding a small screwdriver or butter knife in to lift the tab so you can pull the piece out. It just takes patience. have a look at the instructions here https://s3.amazonaws.com/spinmasterstudi...
这个答案有帮助吗?
得分 2
添加一条评论
Sadly, I did this (wasn’t even the kids) when trying to put it together.. I found nothing online for a fix. I took apart the screws on the base piece. There are 2 on the outside and a few on the inside. This allows you to take out the periscope and the piece its attached to.
There are two screws on the bottom of this piece (red). After taking these two screws out you can see why you couldn’t pull it apart!!! At this point, I tried with screw drivers pulling at the tabs (two at a time), although they were tough, one eventually did break. The piece was then able to be pulled/pushed out and came undone. I was able to reassemble it properly and it all works without issue. I’m sure there is a way to get it out without breaking it, but no luck for me.
Hope it helps
CK
这个答案有帮助吗?
得分 2
1条评论:
Your post saved Christmas, worked exactly as you said, thanks so much
完成的
添加一条评论
We had the same thing happen! We pulled really hard at an angle & got the periscope out…good luck!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Cdws 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 37
过去 30 天: 162
总计 20,259
