跳转到主内容
For 1992 the Grand Am received new body work and a revised interior. A V6 option returned in the form of the 160 hp 3.3 L 3300 V6. The 2.3 inline four came as either a SOHC or DOHC.
5 个问题 查看全部
Is is any good for the head to come off with the valve cover
Ineed to when I try to take off the valve cover and the heads are coming off to
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Are we the engine ??? 'The-valve-cover' implies 1 cover, like a 4cylinder. 'Heads' imply 2 heads, like a V6 engine.
Which engine is it ? How many bolts have you removed ?
Old engines often have 'stuck' covers, from the goopy-soaked gasket holding it to the head. Do not force it off. Some gloves and a hot-air hair-dryer will soften the goop and allow removal. While it is hot, scrape the old gasket away.
完成的
添加一条评论
1个答案
The engine head(s) will not come off, until the exhaust and intake manifolds are removed.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Christina McGuire 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 48
