跳转到主内容
Repair and disassembly guides and support for dish washing appliances.
705 个问题 查看全部
Whirlpool dishwasher won't start, model WDT710PAYM
When pressing the start button the Sani Rinse and Overnight buttons light up and there is a beep for a second and then the lights go off.
Press other buttons just gives a beep and no light.
I can't find any answers on how to fix it, please help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Cause 1
Thermal Fuse
The thermal fuse shuts off power to the dishwasher if it overheats. If the thermal fuse blows, it will prevent the dishwasher from starting. To determine if the thermal fuse is defective, use a multimeter to test the fuse for continuity. If the thermal fuse does not have continuity, replace it.
Cause 2
Door Switch
The door switch prevents the dishwasher from running while the door is open. If the door switch is defective, the switch will prevent the dishwasher from running even when the door is closed. To determine if the door switch is at fault, use a multimeter to test the switch for continuity. If the switch does not have continuity, replace it.
Cause 3
Door Latch
The door latch ensures that the dishwasher door latches shut. If the door does not latch properly, the door switch might prevent the dishwasher from running. If the door latch is broken, replace it.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Tim W 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,775
