跳转到主内容
Repair guides and support for C/K pickup trucks sold by General Motors under the GMC brand, including the GMC Sierra.
77 个问题 查看全部
Transmission won't go when put in 1st or 2nd gear
I have a 1994 gmc 4x4. When you put the truck in 1st or 2nd it will not go. When in drive or over drive it shifts through all gears with a small slip between 2nd and 3rd. Anyone know what may cause this
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
This is sounding like a transmission problem. I would take it to your nearest auto repair shop and have them take a look at it, as gear slipping and not going on certain gears is a clear sign that something is wrong with it.
这个答案有帮助吗?
得分 0
3条评论:
I know it's a transmission problem just trying to see if anyone has had similar problems and what the cause of it is
完成的
What transmission is in it? Sounds like your friction plates are what is causing the slip. But also if it isn't a physical issue preventing movement, it could be solenoid issues if it is an electric trans. Hence why I asked. I have a couple of transmission repair manuals that also have a troubleshooting section.
完成的
4l60e transmission
完成的
添加一条评论
添加你的答案
JASON HENDRIX 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 8
总计 111
