跳转到主内容
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
250 个问题 查看全部
Can the iPad smartcover magnets destroy my credit cards?
If I have the iPad in my bag, close to my wallet with the credit cards – will I get problems? I mean, even a bag with a magnet clip managed to erase data and made my bank card unusable ...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
This question was migrated from http://meta.ifixit.com/.
完成的
添加一条评论
15个答案
最有帮助的答案
I'm sure apple will say they tested it but Id rather not take any risk. I'd keep anything with magnetic strips or data well away or shielded.
这个答案有帮助吗?
得分 4
添加一条评论
Technically, yes. However, it is not very plausible. The magnets used in the cover and the iPad itself have a very limited range of influence, and only in direct contact is the magnetic flux any appreciable strength.
What this means is that it is possible, but only if you repeatedly drag your credit cards magnetic strip across the magnets. This is the only way to reliably overcome the magnetic domains, as they are clustered together, making them more resistant to change.
Think of the bed of nails magic trick. The dude can lay on it without pain because the force is distributed equally. the same applies to clustered magnetic information on physical media.
However motel/hotel cards have a different information structure, and much less of it at that, and likely use a cheaper magnetic strip formulation.
In conclusion, just don't use your credit/bank card to pry the cover off!
这个答案有帮助吗?
得分 3
添加一条评论
I doubt it, I've never been able to demagnetize a credit card, and other than one cheap hotel room key, I haven't been able to demagnetize any magnetic strip. I think you'd need a) strong magnets b) to actually try
这个答案有帮助吗?
得分 1
1条评论:
All my ID badges with strips for entry to work rooms were "blanked" after I put them next to my iPhone case... It was only a small magnetic catch... Can't comment on credit cards but didn't want to experiment! The hassle of being locked out of rooms for days until the badges were fixed was enough for me. I'm sure they are far more foolproof/intricate than my silly badge but hey....
完成的
添加一条评论
it can but it is unlikely. The strip on a credit card is a constant repeat of the credit card information over and over and over again. You would have to run the magnetic strip over the magnet to do damage.
这个答案有帮助吗?
得分 1
添加一条评论
Cept anyone with a rfid reader can copy the fob or card information and use it. It can be done with less than 50$ worth of equipment.
这个答案有帮助吗?
得分 1
添加一条评论
I managed to demagnetize a hotel key with my iPad once - but i doubt credit cards that easily affected.
Also, the magnets are in the iPad itself - not the covers.
这个答案有帮助吗?
得分 1
添加一条评论
As this iFixit article clearly shows, there are actually 21 magnets in the Smart Covers themselves. 10 in the iPad.
这个答案有帮助吗?
得分 1
添加一条评论
it is impossible to wipe a card with the magnets of the ipad/smart cover.
wiping cards with magnets was tested on the show "mythbusters" and they tried with extremely powerful electronic magnets, and didnt manage to wipe a card, i wouldnt be worried, at all.
这个答案有帮助吗?
得分 1
1条评论:
It isn't the strength of the magnet as much as it is the duration of contact between the magnet and the card. I learned this from a site "creditcards .com" Credit cards have a better retention rate than cards that are meant to be rewritten like hotel room keys or employee pass keys. My employer just went to magnet employee name badges, so I was doing some research on the subject myself. Not all magnetic stripes are the same.
完成的
添加一条评论
Not only can it, but it already has. Plus just today I talked with someone who had their electronic motel key erased and they could't get in their room.
这个答案有帮助吗?
得分 0
1条评论:
完成的
添加一条评论
Isn't this common knowledge? Buy a ^$!& cover for your cards or use RFID cards... My fobs, cards are not affected because new technology is RFID.. And it's not new tech..
If your card is not working 99.999 % of the time it is the stores terminal. They are never maintained or cared for... Stop blamin mystical magnets for your cards. I'm at a hotel now.. My room key made love to the spline of my cover ... And no problems
If you really could mess up cards.. I would place rare earth magnets across the city and watch the banking industry fall at my hands... Muhhhahah ... You see how silly I sound.. That's how I feel after reading some of these answers
这个答案有帮助吗?
得分 0
1条评论:
If a hotel pass or employee id were placed together with an employee name tag that has a magnetic backing fastener on it in a purse overnight, or in pants pocket, there would be a problem with the card not reading. Magnetic stripes on cards meant to be rewritten are not the same as those on credit cards. SO YES, you really can mess up cards if you are not careful to keep magnet name tags, wallet closures, refrigerator magnets etc away from them. You are not always given a choice of an RFID type card when you are assigned a card to swipe for entry into a POS or other work terminal/copy machine/door entrance.
完成的
添加一条评论
As a compliance officer and technology developer for the credit card and prepaid card industry, I can say with 100% c certainty that ANY magnetic device can affect the magnetic stripe of credit cards.
The magnetic stripe uses technology similar to that of a cassette tape. The magnetic stripe is coded with your card data. Like a cassette tape, if you place a card too close to any magnetic source you risk erasing some or all of the data.
这个答案有帮助吗?
得分 0
添加一条评论
Demo: http://youtu.be/si1MpUdyfKY
In case you don't have 30 seconds to watch the video, it only took one wipe.
这个答案有帮助吗?
得分 0
添加一条评论
It certainly does. I had to replace my credit cards already for a fourth time not knowing the reason for it, until I realized it was the magnet of the iPad cover.
Not only it has destroyed all of my credit cards, but also it has ruined my Kindle screen (and I am not sure if it can be fixed or have to replace the screen....)
This is the "only" problem I had with my iPad, and I will not give it up just fot that. I guess I will have to buy a shielded wallet for all my credit cards!
这个答案有帮助吗?
得分 0
添加一条评论
Yes, the Smart Cover on my iPad mini has managed to erase my work ID badge twice now, and it's such a hassle for both me and the IT guy who has to reprogram my badge.
这个答案有帮助吗?
得分 0
添加一条评论
I need to demagnetize my iPad Air's smart case, help!!anyone can help me out with this???
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lovey Wymann 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 32,114
