跳转到主内容
An all-new Passat, based on the Volkswagen Group B5 platform, was launched in 1998 in North America.
42 个问题 查看全部
Car is hard starting
My 2001 Volkswagen Passat 1.8t is hard starting when hot or cold and I have to crank over the engine and turn the key off and try again and again before it will start. When it does start it usually idles really low until it finally catches up to normal.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
This question was migrated from https://meta.ifixit.com/Answers.
完成的
添加一条评论
2个答案
Even though it does sound a lot like a Fuel pump/fuel pressure issue. Get your car scanned just in case. Fuel pump won't throw a code though.
When you have the codes and aren't sure, post back here.
这个答案有帮助吗?
得分 0
1条评论:
Air flow and throttle show a short circuit .wiring okay
完成的
添加一条评论
check your fuel pump in case fuel is not pumping. In case, it's not fuel pump, check the fuel filter if its not that then it is starting sensor. these are the three likely suggestions for the hard starting in VW passat.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Stephen Ryan Bearden Madison E 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 32
总计 1,223
