跳转到主内容
This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
314 个问题 查看全部
Lower Screen on DS is broken and shattered?
My Lower Screen on my Nintendo DS is broken, and seems shattered from the inside. As if someone stepped on it. I haven't played with it, let alone looked at it in years. What parts are broken, and what parts will I need to fix it?
Update (03/20/2018)
It is actually a DS lite*
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @hahnuh ,
Hopefully only the lower LCD / touchscreen is the problem.
Here is a link to the ifixit Nintendo DS Lite Lower LCD Replacement guide. The guide also lists what tools are required to effect the repair.
Use this guide to inspect the rest of the device to see if there is any further damage to the device and then it is for you to decide whether a repair is worthwhile or not
Here is a link to suppliers of the replacement part. It is not a recommendation to use any of them. It is shown to give an idea of the cost of the part. There are other suppliers online that may suit you better. Just search for Nintendo DS Lite LCD replacement part.
Hopefully this is of some help.
这个答案有帮助吗?
得分 2
1条评论:
EDIT: When or if you do get a replacemnet LCD, make sure it also contains the digitizer layer (the actual touch screen) in the matching color for your console because these can be really annoying to remove and reuse. They almost always irreversibly break upon removal.
完成的
添加一条评论
添加你的答案
Hannah Wilkins 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 738
