跳转到主内容
于2016年3月上市。型号 SM-G930V。
425 个问题 查看全部
Phone dies at 70% with new ifixit battery
Hi yall!
So I swapped out my phones battery with an ifixit replacement about 2 weeks ago and it was working great up until a few days ago. It just shuts down at around 70% and needs to be recharged from 0%. There was one time where I put it on the charger after it died and it would read 69% but would keep dying instantly unless it reached 70% capacity.
This happens multiple times a day and my phone is useless most of the day. Is there any way to fix this? I also still have the original Samsung battery but I bent it a little bit while removing it. Is the original battery safe for usage until this gets sorted?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Did you follow the instructions correctly that came with the new battery? Like charging it up to 100% and let it drain to 5% and then charge again?
完成的
添加一条评论
3个答案
最有帮助的答案
Battery is faulty. Lithium-ion batteries don't need calibration.
这个答案有帮助吗?
得分 3
1条评论:
OP, if you bought from iFixit, contact support (help.ifixit.com) and they should replace it.
完成的
添加一条评论
I am having issues as well. In the last few days is has been discharging fast. I am using the battery saving mode on phone but still dies fast. I had 18% this morning and it shut down. I have contacted support awaiting a reply. I installed this about two weeks ago along with a new camera lense glass.
这个答案有帮助吗?
得分 0
添加一条评论
Faulty battery send it back, You should get a refund
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jesus Valenzuela 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 782
