跳转到主内容
The Dyson V6 Motorhead Vacuum is a lightweight, cordless vacuum. It easily converts for handheld cleaning using a simple dirt bin instead of replaceable trash bags.
Why is the brush roller sticking for v6 vacuum
teeth on lower roll insert that can interfere with teeth on the housing. My brush roll will not turn when re-installed. It installs easily, powers up, spins about 4-5 revolutions, then shuts off power for a second, then comes back on without roller spinning at all. I can see it is the teeth interlocking but don't know how long it makes the first 4 or 5 revs.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Did you find a solution?
完成的
my roller will not turn on my v6 dyson but a new roller will do i have a problem with the old roller or is the problem with the cogs that turn the roller?
完成的
添加一条评论
1个答案
已选择的解决方案
Pull the roller and examine it and see if the cogs are worn. Jere’s how:
Dyson V6 Motorhead Brush Bar Replacement
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Ryan Burns 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 14
总计 4,525
