跳转到主内容
Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
376 个问题 查看全部
I get this message when trying to burn DVD's"Device failed to calibrat
Whenever I try to burn DVD's I get this message "device failed to calibrate the laser power level for this media".
I cleaned the lens, tried different Dvd's, changed the language settings to no avail. It can read them (most of the time), it can read Cd's fine.
Anyone can help me?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
最有帮助的答案
I recently had the exact same problem with my 2007(ish) MBP. Did some research around the web (and iFixit, of course) to find some solutions and all I needed to do was reset the PRAM. Followed the steps, popped in a blank DVD, burned a few .MOV files to it and all is well again. Check the instructions here:
http://support.apple.com/kb/ht1379
Hope that helps!
-P
这个答案有帮助吗?
得分 1
添加一条评论
Bad DVD drive
- happens a lot. Probably need to replace it.
Good Luck,
N.
这个答案有帮助吗?
得分 0
添加一条评论
Hi.
I had the same problem, but only with double-layer DVDs. Since I hadn't tried burning these too ofter, over 2 yrs passed before I actually tried burning one of these for the first time. Each time, no matter what brand the blank DVD-DL was, I had the calibration error message.
I called Apple Poland (that's where I'm from) and - behold - they told me they would replace the drive with a new one free of charge, even though I was already past the warranty period.
Maybe this is what you need to do, too - even though your problem pertains to all - I assume - kinds of DVDs, not just the DL's.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Hughes Boutin 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 3
总计 922
