跳转到主内容
于2015年十月26日上市的第四代Surface Pro平板电脑。
Screen Replaced but touch screen doesn't work
So I just replaced the screen on a surface pro 4, however the touch screen doesn't work when i use my fingers. It works fantastic with the pen and with the keyboard, but not when I use my fingers. The cables are seated properly so I don't know what the issue could be.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Did you double check the digitizer board behind the screen to see if the ribbon cables are fully inserted and clipped in?
这个答案有帮助吗?
得分 2
8条评论:
yea they're all seated and everything. the digitizer works, the screen cuts on and everything. i just can't use my fingers.
完成的
The touch screen is defective on the screen, which is pretty unfortunate.
I'm guessing you already checked the touch screen cable that plugs into the surface logic board and the mini board on the screen.
完成的
aww man! I did check the cables on the ntrig and the other cables as well. they're all seated properly. im going to do another check and then have someone else look at it to double check. i haven't sealed it yet so that's the good news.
完成的
Just checked it, the emi shield was messing with the touchscreen connector. thanks so much for all of your help!!
完成的
I have a similar problem, I replaced my screen on SP4, everything seems to be connected properly, I checked various times but half of my screen does not respond to touch, any ideas?
完成的
显示更多的3条评论
添加一条评论
添加你的答案
LMJ 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 1,692
