跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1525 个问题 查看全部
I can still not get it to turn on
I have replaced everything I can think of to replace other than the motherboard and this iPhone 6 plus it has a brand new digitalizar it has a brand new battery brand new power port Charger brand new charging cord and charging Outlet it has brand new camera brand new power main home button everything I have tried to do to this iPhone 6 plus I can still not get it to turn on
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Measure your board. Is there waterdamage?
完成的
I've tried the pats in my brothers phone and they all work
完成的
添加一条评论
2个答案
已选择的解决方案
There is always the possibility that some of the replacement parts you used were defective themselves. That is not an uncommon occurence. The only way to troubleshoot a phone is to use known-good parts. That can be difficult for a DIY repair.
Assuming all the parts ARE good, then you have a logic board issue. This would require a micro-soldering repair and is not typically DIY.
这个答案有帮助吗?
得分 2
添加一条评论
If you've tried all the parts in another device and they work, then it would appear that the motherboard is the problem. Have you tried checking to see if the device is stuck in DFU/Restore mode? I've come across a few devices where they appeared to have no life at all. And after a few attempts of holding down both the power & home button, and releasing the power button after 10 seconds, the device turned on. It's best to do this while the device is plugged in to iTunes with the volume on the computer up, so you can hear if the device is connecting/disconnecting from the computer.
这个答案有帮助吗?
得分 0
1条评论:
I tried all of that but the iTunes parts and changing the motherboard I will give it a shot thanks
完成的
添加一条评论
添加你的答案
Kyle 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 58
